Home
The MT-03 Autogyro
Training
RotorSport
Club
Contact
Links
MT-03 Video
Aircraft Shares
MT-03
Squadron
About the MT-03
The MT-03 is an all new
aircraft designed and developed in Germany, and now, in partnership with
RotorSport UK, has been developed to be the best in the world in showing
full compliance with BCAR Section T, the toughest airworthiness standard
around for Sport Gyroplanes. The aircraft will also have the proud
distinction of being the first two-seater to
have done so.
It's an aircraft which is "right" from the ground-up, featuring:
- Tandem two-seat design
- Stainless steel fuselage
- High-tech composite bodywork &
horizontal stabiliser
- 100hp Rotax 912S engine or
115hp Rotax 914
- Superb quality factory build
and finish
- High performance aluminium
rotor system
- 70-litre fuel capacity
- Pneumatically adjustable
in-flight trim
- Disk brakes on the main wheels
with lockable parking brake
- Useful load of over 210kg
- Quiet - meets strict German
noise regulations
- Good looks (and great
colours!)
Technical Information:
| Empty weight |
239 kg |
| Max Take-Off
Weight |
450 kg |
| Payload |
211 kg |
| Vne |
100 mph |
| Cruise Speed |
80 mph |
| Minimum Speed
20 mph |
| Rate of climb |
980 fpm |
| Take-off
distance |
10 m - 70 m |
| Landing
distance |
0 m - 15 m |
| Fuel capacity |
70 litres |
| Range |
over 300
miles |
| Height |
2.7m |
| Width |
1.82m |
| Length |
4.95m |
